Введение
This guide will show how to replace the camera on a LG X Power smartphone.
Выберете то, что вам нужно
Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
Pull the cameras out to remove them.
