Введение
This guide will show you how to replace the LCD screen on a LG X Power smartphone.
Выберете то, что вам нужно
Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
Pull the cameras out to remove them.
Insert a plastic opening tool underneath the motherboard and pry upwards to remove it.
Carefully peal off the glued vibration motor by using the plastic opening tool.
17 человек успешно провели ремонт по этому руководству.
7 Комментарии к руководству
If you are just replacing the screen, this is wrong. This would help if you are replacing with a “screen in frame”
What is the right way for just the screen?
Where’s the part where you actually remove the screen and add in the new one?
The last step seems to be prying off the ear speaker.
Could you please fix this guide when you get the chance? I might replace the screen on my LG Power X [K210]. Thanks.
