Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Removing the motherboard is for more serious problems or problems having to do with the screens. It can be tricky so be very careful.
Выберете то, что вам нужно
Placing your thumb on the bottom of the phone, apply pressure to the small ridge in the middle of the phone and push upward towards the camera.
The back casing should slide off.
Using your index finger, pull the top of the battery out first. Place your finger at the top center of the battery in the gap that is provided. Then pull the battery towards yourself.
The battery should easily fall out after the top of the battery has been pulled out.
Unscrew the six 2.4mm Phillips #00 screws (three on the left and three on the right of the phone) to remove the inner back case.
Once all six screws are removed, use the plastic opening tool to carefully pry apart the inner back case. Push the plastic tool underneath the case. Carefully push upward, with the tool, while moving it around the case.
Carefully remove the two 3mm Phillips #00 screws (one on the top and one on the bottom) that are attaching the motherboard to the phone.
For this next step, carefully lift and remove the motherboard.
A connector cable will still be connected to the motherboard upon removing it.
Once the cable is removed, you have successfully disassembled the motherboard of your phone.
Еще один человек закончил это руководство.
