Введение
In this guide you will be removing the front panel from the rest of the phone to access the front keyboard.
Выберете то, что вам нужно
Place the phone face down on the table.
Use your fingernail or an opening tool to pull down the tab below the battery.
Lift the battery out.
Locate the five rubber covers on the back panel of the phone.
Use the metal probe to pop out each rubber cover to reveal the screws underneath.
Locate the six 2.5mm screws on the back panel of the phone.
Use a #00 Phillips screwdriver to remove each 2.5mm screw.
Locate the seam around the edge of the phone.
Insert the plastic opening tool into the seam and pry gently to release the tabs.
Work your way around the phone until all tabs are released.
Remove the back panel of the phone.
Insert the plastic opening tool in the crease and move it along each edge of the phone.
Separate the front panel from the rest of the phone.
Open the phone to reveal the inside monitor.
Use a Phillips #00 screwdriver to remove two 2.5mm screws.
Using your hands, separate the front panel from the phone by carefully pulling it straight off.
Place the front panel so that the buttons face upwards.
Push on the buttons to remove the keyboard from the front cover.
2 участников успешно повторили данное руководство.
