Введение
Use this guide to replace your LG-P970 touch screen.
You can buy this part on amazon http://www.amazon.fr/dp/B00CF29W78
Выберете то, что вам нужно
remove the back cover
remove the battery
remove the SIM card
remove the µSD card (Memory)
remove 7 screws on the back
with a tool start to open the back frame
and it's now easy to remove the back frame with hand, carefully
don't forget to remove the little connector of screen, with a tool, right next to the empty slot of the camera.
the touch panel is glued with double-sided tape. You can remove it with your fingers. carefull with the touch screen connector.
cut new double sided tape (1-2mm width), put it on the are and peel it.
remove the inside protection on the new touch screen.
carefully put the news touch screen on the LG. Take care that the connector goes right through the right hole.
to finish, add all part by reading these instructions in reverse ;-)
and try if it work !
19 участников успешно повторили данное руководство.
