Введение
Use this guide to replace your LG-P970 touch screen.
You can buy this part on amazon http://www.amazon.fr/dp/B00CF29W78
Инструменты
No tools specified.
Запчасти
  1. remove the back cover remove the battery remove the SIM card
    • remove the back cover
    • remove the battery
    • remove the SIM card
    • remove the µSD card (Memory)
  2. remove 7 screws on the back with a tool start to open the back frame and it's now easy to remove the back frame with hand, carefully
    • remove 7 screws on the back
    • with a tool start to open the back frame
    • and it's now easy to remove the back frame with hand, carefully
  3. remove buttons locate the back camera with a tool raise up the led.carefully
    • remove buttons
    • locate the back camera
    • with a tool raise up the led.carefully
  4. with a tool disconnect the back camera and remove the camera with your fingers. and remove the camera with your fingers.
    • with a tool disconnect the back camera
    • and remove the camera with your fingers.
  5. don't forget to remove the little connector of screen, with a tool, right next to the empty slot of the camera. don't forget to remove the little connector of screen, with a tool, right next to the empty slot of the camera.
    • don't forget to remove the little connector of screen, with a tool, right next to the empty slot of the camera.
  6. It's time to remove carefully the tactile screen. don't scratch le LCD!!! don't scratch le LCD!!!
    • It's time to remove carefully the tactile screen.
    • don't scratch le LCD!!!
  7. the touch panel is glued with double-sided tape. You can remove it with your fingers. carefull with the touch screen connector. cut new double sided tape (1-2mm width), put it on the are and peel it. cut new double sided tape (1-2mm width), put it on the are and peel it.
    • the touch panel is glued with double-sided tape. You can remove it with your fingers. carefull with the touch screen connector.
    • cut new double sided tape (1-2mm width), put it on the are and peel it.
  8. remove the inside protection on the new touch screen. carefully put the news touch screen on the LG. Take care that the connector goes right through the right hole. to finish, add all part by reading these instructions in reverse ;-)
    • remove the inside protection on the new touch screen.
    • carefully put the news touch screen on the LG. Take care that the connector goes right through the right hole.
    • to finish, add all part by reading these instructions in reverse ;-)
    • and try if it work !
Заключение
18 участников успешно повторили данное руководство.
Fox4EGX
Участник с: 01.10.2012
515 Репутация
1 Guide authored
Один комментарий
Hi. To take the screws out do I need a phillips? Thanks.
schutze61 - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 1
За 7 дней: 1
За 30 дней: 5
За всё время: 9,342
