Введение
Use this guide to replace a fan blade in your Lasko B20540 20" 3-Speed Power Plus Box Fan.
Box fans serve as an affordable way to keep cool during warm seasons. If the fan blade is broken, the fan may not work as intended. This guide will take you through the steps to safely remove the fan blade and replace it with a new one. With a new blade installed, the fan will work properly, and be sure to help keep you cool and comfortable.
Выберете то, что вам нужно
Locate the six 16.0 mm Phillips #2 screws around the frame.
Use a Philip's #2 bit (PH2) screwdriver to remove them.
Firmly grasp the front face of the fan. Lift up to remove the face, and set it aside.
Firmly grasp the base of the blade. Lift up until the blade is removed, exposing the motor.
Take the new blade and align the center of the base with the motor. Push down on the blade firmly until the blade is secured.
Place the face of the fan back in its original position, making sure to align the holes for the screws.
Once the frame has been screwed back into place, the fan can now be plugged in and turned on.
