Le Pan S Battery Replacement
Выберете то, что вам нужно
  1. Le Pan S Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
    • This cover is adjacent to the volume button on the side of the Le Pan S.
  2. Le Pan S Battery Replacement: шаг 2, изображение 1 из 2 Le Pan S Battery Replacement: шаг 2, изображение 2 из 2
    • Insert the spudger between the front and back panel in order to pry them apart.
    • Do this beside the volume button and the micro SD cover.
    • Pry open the rest of the Le Pan S by dragging the spudger across the side.
  3. Le Pan S Battery Replacement: шаг 3, изображение 1 из 1
    • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
  4. Le Pan S Battery Replacement: шаг 4, изображение 1 из 2 Le Pan S Battery Replacement: шаг 4, изображение 2 из 2
    • Disconnect the battery from the circuitry and lay it out of the way.
    • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
    • If you are replacing your battery, make sure to dispose of it properly.
Заключение
3 участников успешно повторили данное руководство.
Maria Dole
Участник с: 09/17/15
395 Репутация
Автор 3 руководств
Команда
IUPUI, Team 2-1, Harley Fall 2015 Участник IUPUI, Team 2-1, Harley Fall 2015
IUPUI-HARLEY-F15S2G1
5 членов
Автор 10 руководств
5 Комментариев
where can I purchase a battery for a tc978
Timothy - Ответить
Hi Timothy, Did you ever find out where to purchase a battery for your Le Pan S tablet?
jatrussel -
But what do I do when it's not the battery, but is the charger is so loose in the tablet, it won;t charge. Once in a while, I can get it to come on if I happened to hold the charger just right. So disgusting. Can this be fixed.? i have purchased two LePans and neither will charge.
cdboers - Ответить
Where can I purchase the battery needed?????????????????
jatrussel - Ответить
Thank you Maria!
Easy to take apart. Disconnected/reconnected battery and voila!
All good.
Be well.
Den E
Denny Ehlers - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 14
За всё время: 5,383
