Выберете то, что вам нужно
Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
Use the plastic prying tools to crack open the back of the device.
Once cracked, use more plastic prying tools to fully remove the back panel. A popping noise will occur when each clip is opened.
Remove the back panel and set aside.
The battery pack is glued to the device.
Use a spudger to pry the battery pack from the glue.
Desolder the positive (red) and negative (black) power leads.
