Введение
This replacement guide will teach you how to remove and replace the front facing camera to your Leader Impression i10A-LE tablet. This fix can take anywhere from 5-10 minutes.
Выберете то, что вам нужно
Start by prying the back off by using plastic opening tools.
Slide the flat end of the plastic tools into the seam device.
Using another plastic tool, slowly pry along the seam until the back pops off.
Locate the Camera in the top left corner of the Leader Impression.
Using the tweezers, remove the bottom of the camera from the motherboard.
The top of the camera will detach as you pull upward.
