Введение
Removing and replacing the microphone for the Leader Impression i10A-LE.
Выберете то, что вам нужно
Orient your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
Pry the back off by using plastic opening tools.
Using the plastic tools slide the flat end into the device.
Gently pry the back piece until you hear a popping noise.
Once the back is loose, remove it from the device and set aside.
Remove the microphone from plastic housing with the tweezers.
Desolder the positive (red) and negative (black) power leads.
