Введение
If there is no sound coming from your device there is a good chance your speakers are broken. This guide will show you how to replace the speakers in the Leader Impression i10A-LE tablet.
Выберете то, что вам нужно
Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
Start by prying the back off by using plastic opening tools
Using the plastic tools slide the flat end into the device.
Gently pry the back piece until you hear a popping noise.
Once the back is loose, remove it from the device and set aside.
Use the spudger to pry both of the speakers from the tablet.
Follow both sets of speaker wires to the motherboard where they are connected.
Desolder the wire connections from the motherboard.
