Введение
Use this guide to remove the back cover of your tablet and replace the battery. Make sure your tablet is turned off before disassembling your device.
  1. LeapFrog LeapPad Platinum Battery Replacement, Battery: step 1, image 1 of 1
    • Place your tablet on a flat surface with the screen facing down.
  2. LeapFrog LeapPad Platinum Battery Replacement: step 2, image 1 of 2 LeapFrog LeapPad Platinum Battery Replacement: step 2, image 2 of 2
    • Using a plastic opening tool, pry off the plastic border by inserting it in the space between the green bumper and the white plastic on the edge of the tablet.
    • The border snaps into place, so don't be too worried if you hear a cracking noise while prying it off.
  3. LeapFrog LeapPad Platinum Battery Replacement: step 3, image 1 of 2 LeapFrog LeapPad Platinum Battery Replacement: step 3, image 2 of 2
    • Remove the 11 Phillips screws (8.0 mm) located around the edge of the back cover with a Phillips screwdriver.
  4. LeapFrog LeapPad Platinum Battery Replacement: step 4, image 1 of 1
    • Pull the back cover off of your device.
  5. LeapFrog LeapPad Platinum Battery Replacement: step 5, image 1 of 3 LeapFrog LeapPad Platinum Battery Replacement: step 5, image 2 of 3 LeapFrog LeapPad Platinum Battery Replacement: step 5, image 3 of 3
    • Wedge a plastic opening tool underneath the battery and lift the battery up.
    • The battery is held in place by an adhesive strip, so it can be difficult to pry off.
  6. LeapFrog LeapPad Platinum Battery Replacement: step 6, image 1 of 1
    • The battery has red, black, and white wires that are all connected to the motherboard through a plastic clip. Unplug this plastic clip to fully remove the battery from your device.
Заключение
2 участников успешно повторили данное руководство.
Brittney Cooper
Участник с: 17.02.2016
191 Репутация
1 руководство автора
UW Tacoma, Team 1-5, Rose Winter 2016 Участник UW Tacoma, Team 1-5, Rose Winter 2016
UWT-ROSE-W16S1G5
4 членов
Автор 8 руководств
One Comment
Any advice on how to fix a stylus go a leap pad platinum? The top is damaged- can I use any stylus or another platinum stylus it just buy a mesh tip? I can’t seem to find any too buy???
Ann-Mariah Thurber - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 8
За последние 30 дней: 40
За всё время: 7,376
