LeapFrog LeapPad Platinum Battery Replacement
Выберете то, что вам нужно
  1. LeapFrog LeapPad Platinum Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Place your tablet on a flat surface with the screen facing down.
    many thanks for this, but can you tell me where to buy a replacement screen please?
    Helen - Ответить
  2. LeapFrog LeapPad Platinum Battery Replacement: шаг 2, изображение 1 из 2 LeapFrog LeapPad Platinum Battery Replacement: шаг 2, изображение 2 из 2
    • Using a plastic opening tool, pry off the plastic border by inserting it in the space between the green bumper and the white plastic on the edge of the tablet.
    • The border snaps into place, so don't be too worried if you hear a cracking noise while prying it off.
  3. LeapFrog LeapPad Platinum Battery Replacement: шаг 3, изображение 1 из 2 LeapFrog LeapPad Platinum Battery Replacement: шаг 3, изображение 2 из 2
    • Remove the 11 Phillips screws (8.0 mm) located around the edge of the back cover with a Phillips screwdriver.
  4. LeapFrog LeapPad Platinum Battery Replacement: шаг 4, изображение 1 из 1
    • Pull the back cover off of your device.
  5. LeapFrog LeapPad Platinum Battery Replacement: шаг 5, изображение 1 из 3 LeapFrog LeapPad Platinum Battery Replacement: шаг 5, изображение 2 из 3 LeapFrog LeapPad Platinum Battery Replacement: шаг 5, изображение 3 из 3
    • Wedge a plastic opening tool underneath the battery and lift the battery up.
    • The battery is held in place by an adhesive strip, so it can be difficult to pry off.
    How do you get that little black loop that the battery wires are wrapped in, out? Does it just pop out? I’m afraid to pull to hard
    Casey Payton - Ответить
  6. LeapFrog LeapPad Platinum Battery Replacement: шаг 6, изображение 1 из 1
    • The battery has red, black, and white wires that are all connected to the motherboard through a plastic clip. Unplug this plastic clip to fully remove the battery from your device.
Заключение
2 участников успешно повторили данное руководство.
Brittney Cooper
Участник с: 02/17/16
191 Репутация
1 руководство автора
Команда
UW Tacoma, Team 1-5, Rose Winter 2016 Участник UW Tacoma, Team 1-5, Rose Winter 2016
UWT-ROSE-W16S1G5
4 членов
Автор 8 руководств
3 Комментариев
Any advice on how to fix a stylus go a leap pad platinum? The top is damaged- can I use any stylus or another platinum stylus it just buy a mesh tip? I can’t seem to find any too buy???
Ann-Mariah Thurber - Ответить
The stylus is PART of the LeapPad so, there's no way to replace it.
Luke Sawczak -
This was very helpful thank you 😁
Luke Sawczak - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 12
За последние 30 дней: 19
За всё время: 7,945
