LeapFrog LeapPad Ultimate LCD Screen Replacement
Выберете то, что вам нужно
  1. LeapFrog LeapPad Ultimate LCD Screen Replacement, Back Panel: шаг 1, изображение 1 из 2 LeapFrog LeapPad Ultimate LCD Screen Replacement, Back Panel: шаг 1, изображение 2 из 2
    • Flip over the Pad to its back side to begin the removal of the back panel.
    • Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
    • This is very difficult to remove , so do be patient. To help remove the seal, both a metal spudger and plastic opening tool may be used.
    • Remove the pen from its place before starting to avoid tangling.
  2. LeapFrog LeapPad Ultimate LCD Screen Replacement: шаг 2, изображение 1 из 2 LeapFrog LeapPad Ultimate LCD Screen Replacement: шаг 2, изображение 2 из 2
    • Once the blue rim is removed, the 12 screws will be visible.
    • Use the Phillips #1 screwdriver to unscrew all 12 screws.
  3. LeapFrog LeapPad Ultimate LCD Screen Replacement, LCD Screen: шаг 3, изображение 1 из 3 LeapFrog LeapPad Ultimate LCD Screen Replacement, LCD Screen: шаг 3, изображение 2 из 3 LeapFrog LeapPad Ultimate LCD Screen Replacement, LCD Screen: шаг 3, изображение 3 из 3
    • The segment connecting the battery to the motherboard will consist of red, white, and black wires.
    • There is a small notch on the segment. Use the curved tweezers to pull the notch in the direction of the battery. this will disconnect the battery from the motherboard.
    • The battery is the bright orange rectangle.
    • The motherboard is the large dark green surface.
  4. LeapFrog LeapPad Ultimate LCD Screen Replacement: шаг 4, изображение 1 из 1
    • Carefully remove the battery from its place and set aside.
    • Removing the battery will fully expose a white and blue ribbon cable that runs beneath the battery.
    • The ribbon cable must be disconnected from the motherboard and removed from the panel.
  5. LeapFrog LeapPad Ultimate LCD Screen Replacement: шаг 5, изображение 1 из 2 LeapFrog LeapPad Ultimate LCD Screen Replacement: шаг 5, изображение 2 из 2
    • The ZIF connector which connects the ribbon cable and the motherboard has a small flap on the top.
    • Use the curved tweezers to to flip the flap up.
    • Once it is disconnected, carefully pull the ribbon cable through the 2 black plastic arches holding it down.
  6. LeapFrog LeapPad Ultimate LCD Screen Replacement: шаг 6, изображение 1 из 1
    • Use a Phillips #1 screwdriver to unscrew the 7 screws on the speaker.
    • 5 will be on the brown part and 2 on the circular blur part.
    • Once it is unscrewed completely, remove the speaker and set aside.
  7. LeapFrog LeapPad Ultimate LCD Screen Replacement: шаг 7, изображение 1 из 1
    • An orange and black ribbon cable connects the motherboard and the area to the side of the panel.
    • There is a switch on top of it.
    • Use the curved tweezers to flip the switch.
  8. LeapFrog LeapPad Ultimate LCD Screen Replacement: шаг 8, изображение 1 из 1
    • Unscrew the 3 screws on the motherboard with a Phillips #1 screwdriver.
  9. LeapFrog LeapPad Ultimate LCD Screen Replacement: шаг 9, изображение 1 из 2 LeapFrog LeapPad Ultimate LCD Screen Replacement: шаг 9, изображение 2 из 2
    • Flip the motherboard over to expose the uderside.
    • There is a wide black ribbon with a swtich. Flip the switch and set aside the motherboard.
  10. LeapFrog LeapPad Ultimate LCD Screen Replacement: шаг 10, изображение 1 из 2 LeapFrog LeapPad Ultimate LCD Screen Replacement: шаг 10, изображение 2 из 2
    • Along the side of the blue panel are 6 screws. Unscrew each of the screws with a Phillips #1 screwdriver.
    • Remove the panel and the remainder of its contents and set aside.
  11. LeapFrog LeapPad Ultimate LCD Screen Replacement: шаг 11, изображение 1 из 1
    • The screen is now exposed and can be removed and replaced.
Заключение
2 участников успешно повторили данное руководство.
Avery Dillon
Участник с: 09/21/18
232 Репутация
1 руководство автора
Команда
University of North Texas, Team S1-G13, Riccardelli Fall 2018 Участник University of North Texas, Team S1-G13, Riccardelli Fall 2018
UNT-RICCARDELLI-F18S1G13
4 членов
Автор 12 руководств
Один комментарий
Where did you find a Replacement screen? Are there any identifying part numbers?
Johan Rodriguez - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 27
За всё время: 4,580
