Введение
Whether your child has cracked the back cover or decided to cover it in make-up, learn how to replace the back cover.
Выберете то, что вам нужно
Before disassembling your LeapPad, ensure your device is shut off.
Push outward on the plastic side panels to remove and reveal battery.
The panels should detach fully from the main device.
Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
Remove all four AA alkaline batteries from the device.
Remove the following screws securing the back cover to the main device:
Two 10.0 mm Phillips screws
Four 4.0 mm Phillips screws
Three 3.0 mm Phillips screws
Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
Move the plastic opening tool around the perimeter of the LeapPad2.
Lift up and remove the rear case from the tablet.
