Введение
Be in charge of your situation, use this guide to replace the battery.
Выберете то, что вам нужно
Before disassembling your LeapPad, ensure your device is shut off.
Push outward on the plastic side panels to remove and reveal battery.
The panels should detach fully from the main device.
Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
Remove all four AA alkaline batteries from the device.
Еще один человек закончил это руководство.
