Введение
In this guide, you will learn how to replace a LeapFrog Scribble and Write motherboard. You will need a soldering iron to remove certain wiring from the motherboard.
Выберете то, что вам нужно
Use a Phillips head screwdriver to remove the screw from the battery compartment on the back of the toy.
Use a Phillips screwdriver to remove the nine case screws from the back of the toy.
Еще один человек закончил это руководство.
