LeapPad Ultra Battery Replacement
Выберете то, что вам нужно
  1. LeapPad Ultra Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. LeapPad Ultra Battery Replacement: шаг 2, изображение 1 из 1
    • Remove the two 5 mm screws that were covered by the sticker.
  3. LeapPad Ultra Battery Replacement: шаг 3, изображение 1 из 1
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
  4. LeapPad Ultra Battery Replacement: шаг 4, изображение 1 из 1
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
  5. LeapPad Ultra Battery Replacement: шаг 5, изображение 1 из 1
    • Remove the hard plastic casing, exposing the motherboard and battery.
  6. LeapPad Ultra Battery Replacement: шаг 6, изображение 1 из 2 LeapPad Ultra Battery Replacement: шаг 6, изображение 2 из 2
    • Disconnect the battery using tweezers or your fingernails.
    • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Gently pry of the battery lose using a spudger or another thin prying tool.
    • Be careful, damaging/puncturing the battery may cause an explosion.
Заключение
To reassemble the device, follow these instructions in reverse order.
7 участников успешно повторили данное руководство.
Ryan Arredondo
Участник с: 08/31/15
246 Репутация
1 руководство автора
Команда
USF Tampa, Team 4-99, Meier Fall 2015 Участник USF Tampa, Team 4-99, Meier Fall 2015
USFT-MEIER-F15S4G99
4 членов
Автор 10 руководств
4 Комментариев
Hi Ryan, will removing the battery delete any of the downloaded apps and saved files?
Michael - Ответить
I’m not Ryan, but I just did this process and the apps and files are all still there.
Kivi Shapiro - Ответить
What is a spudger and where do I get a battery
P Mac - Ответить
Hello, if anyone still has this leappad Ultra and wanted to purchase a new battery. I have found a retail store https://batteryclerk.com/ The price is reasonable, and I'm just waiting for the batteries to arrive.
Mike Silva - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 9
За последние 30 дней: 34
За всё время: 16,112
