Введение
This guide is rather lengthy as many components must be removed to access the rear facing camera. However, few tools are required and is over all an easy fix.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95
Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
Disconnect the audio cord from the motherboard using a plastic opening tool.
Unscrew the five 6.0 mm phillips head screws from the board containing the audio jack and directional pad.
Unscrew the three 6.5 mm phillips head screws holding down the speaker to the right of the audio jack.
Remove the board and speaker from the device.
Unplug the front facing camera cord with an opening tool to free the top of the motherboard.
Remove the three 6 mm phillips head screws holding the motherboard to the display assembly.
Carefully lift the motherboard out of the case, exposing the last remaining cord on the underside of the motherboard.
Disconnect the gold display assembly cord with an opening tool to fully disconnect the motherboard.
Unplug the rear facing camera located in the top center of the motherboard.
2 участников успешно повторили данное руководство.
