Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide
Выберете то, что вам нужно
  1. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide, Battery: шаг 1, изображение 1 из 1
    • Flip over device so that back portion of the device is facing you.
  2. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: шаг 2, изображение 1 из 1
    • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
    • Please note that the screw cannot be removed as it is attached to the battery cover.
  3. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: шаг 3, изображение 1 из 2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: шаг 3, изображение 2 из 2
    • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
    • Remove the three AA batteries.
    • Note the direction of the batteries for when reassembling.
  4. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide, Keyboard Buttons: шаг 4, изображение 1 из 1
    • Remove the eleven 10mm screws from the back of the device with a a PH1 phillips head screwdriver.
  5. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: шаг 5, изображение 1 из 1
    • Carefully remove back of the device.
    • Make sure not to rip the wires when lifting the cover off.
  6. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: шаг 6, изображение 1 из 2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: шаг 6, изображение 2 из 2
    • Remove the three 10mm screws from the upper left hand corner white plastic piece with a PH1 phillips head screwdriver.
    • Unscrew the five 4mm screws from the plastic membrane with a PH1 phillips head screwdriver.
  7. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: шаг 7, изображение 1 из 1
    • Remove the white plastic piece and place it to the side.
  8. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: шаг 8, изображение 1 из 3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: шаг 8, изображение 2 из 3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: шаг 8, изображение 3 из 3
    • Gently grab the membrane and peal it upwards.
    • Carefully remove the membrane and set it to the side.
    • From this step you can also clean the membrane of any residue with a lightly dampened paper towel.
    • Ensure that the membrane is completely dry before reassembly.
  9. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: шаг 9, изображение 1 из 2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: шаг 9, изображение 2 из 2
    • Gently lift and remove the foam piece
  10. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: шаг 10, изображение 1 из 3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: шаг 10, изображение 2 из 3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: шаг 10, изображение 3 из 3
    • From here, each button is able to be removed for cleaning or replacement.
    • Using a tweezers or needle nose pliers, remove the necessary pieces from the device.
Заключение
2 участников успешно повторили данное руководство.
Jonathan Fitzer
Участник с: 02/10/16
584 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 14-6, Lacy Spring 2016 Участник USF Tampa, Team 14-6, Lacy Spring 2016
USFT-LACY-S16S14G6
4 членов
Автор 6 руководств
6 Комментариев
Very useful. but where to get a new membrane? please help
Alina Timchenko - Ответить
Didn't work. I'll buy a new toy.
victoria_nglover19 - Ответить
Is the screen on this suppose to light up?
stewartmelinda41 - Ответить
I was wondering if the screen is suppose to light up because the one I have doesnt
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 8
За последние 30 дней: 26
За всё время: 5,162
