Left Nintendo Switch NES Controller Charging Rail Replacement
Выберете то, что вам нужно
  1. Left Nintendo Switch NES Controller Charging Rail Replacement, Unscrew the back casing: шаг 1, изображение 1 из 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Unscrew the back casing: шаг 1, изображение 2 из 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Unscrew the back casing: шаг 1, изображение 3 из 3
    • Use a Tri-point #Y00 screwdriver to remove the six 6.0 mm screws securing the back case.
    • Remove the back case from the controller.
  2. Left Nintendo Switch NES Controller Charging Rail Replacement, Unscrew the battery housing: шаг 2, изображение 1 из 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Unscrew the battery housing: шаг 2, изображение 2 из 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Unscrew the battery housing: шаг 2, изображение 3 из 3
    • Use a Phillips #000 to remove three 3.0 mm screws holding the battery and it's housing.
    • Remove the battery housing with the battery from the main board and set it aside.
    • At this point the battery is still attached to the motherboard by a connector so don't pull it off the board.
    • If you're not replacing the battery, you can leave it attached to the board to complete the repair, just be careful when moving them so you don't damage the connection.
  3. Left Nintendo Switch NES Controller Charging Rail Replacement, Pry the ZIF connectors up: шаг 3, изображение 1 из 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Pry the ZIF connectors up: шаг 3, изображение 2 из 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Pry the ZIF connectors up: шаг 3, изображение 3 из 3
    • Use the tip of a spudger or your fingernail to flip up the small locking flaps on the two ZIF Connectors. Then, you can safely pull the cable out.
    • Be sure to pry up on the hinged flap, not the connector socket.
  4. Left Nintendo Switch NES Controller Charging Rail Replacement, Remove the charging rail: шаг 4, изображение 1 из 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Remove the charging rail: шаг 4, изображение 2 из 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Remove the charging rail: шаг 4, изображение 3 из 3
    • Use a Phillips #000 to remove the single 3.0 mm screw holding the charging rail to the back plate.
    • Remove the charging rail.
  5. Left Nintendo Switch NES Controller Charging Rail Replacement, Remove the rail PCB: шаг 5, изображение 1 из 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Remove the rail PCB: шаг 5, изображение 2 из 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Remove the rail PCB: шаг 5, изображение 3 из 3
    • Use a Phillips #000 screwdriver to remove two 3.0mm screws from the rail PCB.
    • Remove the charging rail PCB.
  6. Left Nintendo Switch NES Controller Charging Rail Replacement, Take the SL, SR and Sync buttons out: шаг 6, изображение 1 из 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Take the SL, SR and Sync buttons out: шаг 6, изображение 2 из 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Take the SL, SR and Sync buttons out: шаг 6, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Купить
    • Using tweezers, remove the SL and SR buttons.
    • Do the same for the Sync button between them.
Заключение
We hope you enjoy your new and improved Charging Rail for your Nintendo Switch NES Controller.
To put the device back together, follow this guide in reverse.
2 участников успешно повторили данное руководство.
Dominik Szwec
Участник с: 01/14/22
148 Репутация
1 руководство автора
Команда
York University, Team M-26, Allen Winter 2023 Участник York University, Team M-26, Allen Winter 2023
YORK-ALLEN-W23SMG26
1 член
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 12
За последние 30 дней: 50
За всё время: 768
