Выберете то, что вам нужно
Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
Open the back door on the camera by pushing down on the door latch.
Apply pressure to the bottom plate and it will pop off.
From here, you can replace the bottom plate, or continue on to further steps.
Having opened the camera and removed the bottom plate, unscrew the five screws marked in the picture.
The screw marked in blue is a tiny bit harder to find because it's in a crevice. Don't miss it!
Unscrew the four screws on the back of this piece to the lower-left corner of the lens.
Now that you've removed the bottom plate, you can pull apart the front and back covers.
Start with the front cover and, by applying pressure (perhaps a lot of pressure), snap off the front cover.
Next, the back cover.
Apply pressure to remove the back plate.
The best way to remove the back is to stick your thumbs on either side of the battery socket and separate from there.
Remove the three gears under the panel you removed in the last step and the lens motor should be able to be removed.
3 участников успешно повторили данное руководство.
