Введение
This guide will show how to remove the battery for the Lenovo 100s Chromebook-11IBY. This removal will allow you to replace or upgrade the battery for your laptop.
  1. Lenovo 100s Chromebook-11IBY Battery Replacement, Battery: step 1, image 1 of 1
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Battery Replacement: step 2, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the nine 6mm screws from the larger back plate.
  3. Lenovo 100s Chromebook-11IBY Battery Replacement: step 3, image 1 of 2 Lenovo 100s Chromebook-11IBY Battery Replacement: step 3, image 2 of 2
    • Turn your laptop back over, open it, and use the plastic opening tool on the recessed notch to gently pry each side and lift the keyboard plate up.
    • Be careful not to pull keyboard plate out immediately because cables are attached.
  4. Lenovo 100s Chromebook-11IBY Battery Replacement: step 4, image 1 of 2 Lenovo 100s Chromebook-11IBY Battery Replacement: step 4, image 2 of 2
    • Unlock the keyboard ZIF connector to release the keyboard flex cable.
    • To unlock a ZIF connector, use an opening tool or your fingernail to flip up the small, hinged locking flap.
    • Unlock the touchpad ZIF connector to release the touchpad flex cable.
    • Carefully pull both flex cables out of the ZIF connectors.
    • Remove the keyboard plate up and place it to the side.
  5. Lenovo 100s Chromebook-11IBY Battery Replacement: step 5, image 1 of 1
    • Unplug the battery cable by pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo 100s Chromebook-11IBY Battery Replacement: step 6, image 1 of 1
    • Use the Phillips #0 screwdriver to remove the three 6mm screws from the battery.
  7. Lenovo 100s Chromebook-11IBY Battery Replacement: step 7, image 1 of 1
    • Remove the battery.
Заключение
For optimal performance, after completing this guide, calibrate your newly installed battery.
2 участников успешно повторили данное руководство.
Milton Perez
Участник с: 09.03.2017
630 Репутация
Автор 5 руководств
USF Tampa, Team S7-G2, Cagle Spring 2017 Участник USF Tampa, Team S7-G2, Cagle Spring 2017
USFT-CAGLE-S17S7G2
1 член
Автор 10 руководств
0 Comments
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 16
За всё время: 2,119
