Введение
This guide will show how to remove the webcam for the Lenovo 100s Chromebook-11IBY. This removal will allow you to replace or upgrade the webcam for your laptop.
Запчасти
Детали не указаны.
  1. Ensure your device is turned off and unplugged.
    • Ensure your device is turned off and unplugged.
  2. Use the plastic opening tool on the recessed notch to gently pry each side of around the screen up.
    • Use the plastic opening tool on the recessed notch to gently pry each side of around the screen up.
  3. Carefully pry up and underneath both the (left & right) hinges of the screen cover. Carefully pry up and underneath both the (left & right) hinges of the screen cover.
    • Carefully pry up and underneath both the (left & right) hinges of the screen cover.
  4. Use the plastic opening tool on the inside of the screen plate and again on the sides to gently remove it. Use the plastic opening tool on the inside of the screen plate and again on the sides to gently remove it.
    • Use the plastic opening tool on the inside of the screen plate and again on the sides to gently remove it.
  5. Gently unplug the wire connecting the webcam to the laptop.
    • Gently unplug the wire connecting the webcam to the laptop.
  6. Using the plastic opening tool, gently lift the webcam panel from the screen. Then remove it. Using the plastic opening tool, gently lift the webcam panel from the screen. Then remove it.
    • Using the plastic opening tool, gently lift the webcam panel from the screen. Then remove it.
Заключение
Milton Perez
Участник с: 09.03.2017
630 Репутация
Автор 5 руководств
Команда
USF Tampa, Team S7-G2, Cagle Spring 2017 Участник USF Tampa, Team S7-G2, Cagle Spring 2017
USFT-CAGLE-S17S7G2
1 член
Автор 10 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 246
