Введение
If your Lenovo 300e Chromebook is having functionality problems, the most likely cause is one of the multiple components of the computer. In order to view these components, the back cover of the computer must be removed. Follow these steps in order to remove the back cover.
The case is one of the most important properties of a computer. It protects the interlinking components of a computer and keeps them safe from foreign objects. A broken computer case can lead to the breakdown of a computer.
Before you start taking your Lenovo 300e Chromebook apart be sure to power off the Chromebook and disconnect from any power source.
This link is forum provided by Lenovo for users with similar problems.
Выберете то, что вам нужно
Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
