Введение
This guide will show how to remove the speakers in the Lenovo 300e Chromebook. The speakers have screws that require the use of a #2 Phillips screwdriver to remove. While not a long or difficult process, the speakers are fragile so make sure to take caution when putting the new ones in.
Выберете то, что вам нужно
Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
Disconnect the wiring harness that connects the battery to the motherboard.
Lift the battery up and out of the laptop.
Remove a single 5 mm screw from each speaker using a Phillips #2 screwdriver.
Disconnect the speaker cable from the motherboard.
Remove the speakers from the laptop.
