Введение
This guide will provide the necessary steps to remove and install the fan in the Lenovo Edge 15. The Edge 15 has the fan and heatsink connected together so the heatsink will be also be replaced in this process.
Выберете то, что вам нужно
Turn laptop over and unscrew the eleven M2 x 6.0mm back cover screws with the Phillips #0 screwdriver.
Remove the five M2 x 4.0 mm screws from the heat sink with a Phillips #0 screwdriver.
2 участников успешно повторили данное руководство.
