Введение
This guide will show you how to remove and replace the fan cooling solution of the laptop if for some reason it has become faulty and needs replacement.
Выберете то, что вам нужно
Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
Disconnect the battery connector from the motherboard.
Using the Phillips #0 screwdriver, remove the (6) six fan screws from the device.
Disconnect the fan from the motherboard.
2 Комментариев
Where can one find this fan?
