Введение
The guide will show you how to remove and replace the RAM module that comes with the laptop. Be sure the new replacement module is compatible with the motherboard.
Выберете то, что вам нужно
Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
Disconnect the battery connector from the motherboard.
With both of your thumbs, gently pull both adjacent levers outwards. The RAM module will rise a bit.
2Комментарии к руководству
but how exactly do i open the cover?
