Введение
This guide will show you how to replace the screen on a Lenovo ThinkPad Edge E431 laptop.
Выберете то, что вам нужно
Remove the 2mm Phillips #00 screw from the battery cover.
Lift the battery cover out of its slot.
Use the pointed end of a spudger to remove the two screw covers from the bottom corners of the display.
Remove the two 2mm Phillips #00 screws found at the bottom corners of the display.
Peel up the adhesive tape to unlatch the metal retaining bracket on the display cable.
3 участников успешно повторили данное руководство.
