Lenovo Essential G560 Hard Drive Replacement
Выберете то, что вам нужно
  1. Lenovo Essential G560 Hard Drive Replacement, Battery: шаг 1, изображение 1 из 1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Lenovo Essential G560 Hard Drive Replacement: шаг 2, изображение 1 из 2 Lenovo Essential G560 Hard Drive Replacement: шаг 2, изображение 2 из 2
    • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo Essential G560 Hard Drive Replacement: шаг 3, изображение 1 из 1
    • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
  4. Lenovo Essential G560 Hard Drive Replacement, Back Panel: шаг 4, изображение 1 из 1
    • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
    a few of my screws are not coming out
    Jonathan Lewin - Ответить
    Same here. I was able to easily remove the 2 middle screws but the rest were just wiggling in place and not coming out at all.
    Denskwik K - Ответить
    I have the exact same problem. I dont know if it is because of the screws or if it is because I am an 11 year old.
    Alex Kuriakose - Ответить
  5. Lenovo Essential G560 Hard Drive Replacement: шаг 5, изображение 1 из 2 Lenovo Essential G560 Hard Drive Replacement: шаг 5, изображение 2 из 2
    • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
    I was having the same problem as the 11 year old from the previous step, and contrary to this note I just stuck my screwdriver under that tab and pried it off. It worked. It wasn’t even hard.
    lmh237 - Ответить
  6. Lenovo Essential G560 Hard Drive Replacement: шаг 6, изображение 1 из 1
    • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
  7. Lenovo Essential G560 Hard Drive Replacement, Hard Drive: шаг 7, изображение 1 из 1
    • Remove the two 5.33 mm Phillips #1 screws holding the hard drive in place.
    • Be careful with these screws, as they can be stripped or lost easily.
  8. Lenovo Essential G560 Hard Drive Replacement: шаг 8, изображение 1 из 1
    • To remove the hard drive from the computer, grab the black tab attached to the hard drive and pull the tab downwards toward the bottom of the laptop.
    • When installing the hard drive, make sure the hard drive label faces down.
  9. Lenovo Essential G560 Hard Drive Replacement: шаг 9, изображение 1 из 1
    • Unscrew the four 5.2 mm Phillips #1 screws. There are two on each side of the drive holding it in the drive bay.
  10. Lenovo Essential G560 Hard Drive Replacement: шаг 10, изображение 1 из 1
    • Pull the drive out of the bay. If all the screws were removed correctly, it should simply slide out.
Заключение
8 участников успешно повторили данное руководство.
Dennis Wong
Участник с: 01/11/13
609 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 18-40, Regan Winter 2013 Участник Cal Poly, Team 18-40, Regan Winter 2013
CPSU-REGAN-W13S18G40
5 членов
Автор 7 руководств
2 Комментариев
In step 1, failure to unplug the cable does not result in electric shock. The power supply voltage is too low for such shock to happen to a human, but it can cause electrical damage to the motherboard. It is always a safe procedure to work on any machine unpowered (both power supply and battery disconnected and/or removed).
In step 9, be sure to remember the direction that the original drive was pointing when removing. The new drive must point the same direction.
rayramirez - Ответить
In Step 3 - after removing the battery, press & hold the power buttton for 5 seconds to discharge any residual power in the circuitry before moving on to Step 4.
Iain - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 20
За всё время: 21,919
