Lenovo Essential G560 Individual Keyboard Keys Replacement
  1. Lenovo Essential G560 Individual Keyboard Keys Replacement, Battery: шаг 1, изображение 1 из 1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Lenovo Essential G560 Individual Keyboard Keys Replacement: шаг 2, изображение 1 из 2 Lenovo Essential G560 Individual Keyboard Keys Replacement: шаг 2, изображение 2 из 2
    • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo Essential G560 Individual Keyboard Keys Replacement: шаг 3, изображение 1 из 1
    • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
  4. Lenovo Essential G560 Individual Keyboard Keys Replacement, Individual Keyboard Keys: шаг 4, изображение 1 из 1
    • Place your pointer finger under the key you want to remove. For extra leverage, use the thumb and rotate the key in the manner shown.
  5. Lenovo Essential G560 Individual Keyboard Keys Replacement: шаг 5, изображение 1 из 1
    • The key will come off with a popping sound.
    • You will now be able to see the mechanism below the key. Clean this area using compressed air, then replace the key.
Заключение
To reassemble your keyboard, push the key back into the original spot.
8 участников успешно повторили данное руководство.
Lawrence Downs
Участник с: 01/11/13
383 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 18-40, Regan Winter 2013 Участник Cal Poly, Team 18-40, Regan Winter 2013
CPSU-REGAN-W13S18G40
5 членов
Автор 7 руководств
2 Комментариев
I used your guide to install the key, thank you. I bought my lenovo keys from this link below
http://www.replacementlaptopkeys.com/len...
keep up the good work.
Resteasy - Ответить
Hello , you can buy single keys on this site:
http://www.laptopkey-europe.eu/
John Pohl - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 10
За последние 30 дней: 22
За всё время: 8,565
