Lenovo Essential G560 RAM Replacement
Выберете то, что вам нужно
  1. Lenovo Essential G560 RAM Replacement, Battery: шаг 1, изображение 1 из 1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Lenovo Essential G560 RAM Replacement: шаг 2, изображение 1 из 2 Lenovo Essential G560 RAM Replacement: шаг 2, изображение 2 из 2
    • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo Essential G560 RAM Replacement: шаг 3, изображение 1 из 1
    • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
  4. Lenovo Essential G560 RAM Replacement, Back Panel: шаг 4, изображение 1 из 1
    • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
    a few of my screws are not coming out
    Jonathan Lewin - Ответить
    Same here. I was able to easily remove the 2 middle screws but the rest were just wiggling in place and not coming out at all.
    Denskwik K - Ответить
    I have the exact same problem. I dont know if it is because of the screws or if it is because I am an 11 year old.
    Alex Kuriakose - Ответить
  5. Lenovo Essential G560 RAM Replacement: шаг 5, изображение 1 из 2 Lenovo Essential G560 RAM Replacement: шаг 5, изображение 2 из 2
    • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
    I was having the same problem as the 11 year old from the previous step, and contrary to this note I just stuck my screwdriver under that tab and pried it off. It worked. It wasn’t even hard.
    lmh237 - Ответить
  6. Lenovo Essential G560 RAM Replacement: шаг 6, изображение 1 из 1
    • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
  7. Lenovo Essential G560 RAM Replacement, RAM: шаг 7, изображение 1 из 2 Lenovo Essential G560 RAM Replacement, RAM: шаг 7, изображение 2 из 2
    • Locate the RAM Sticks in the computer. They should be in the corner of the laptop.
  8. Lenovo Essential G560 RAM Replacement: шаг 8, изображение 1 из 2 Lenovo Essential G560 RAM Replacement: шаг 8, изображение 2 из 2
    • Using a spudger, push one of the metal rods on either side of the RAM stick away from it until you hear a light clicking noise. Repeat this procedure on the other metal rod on the opposite side of the RAM stick.
    • If you push both metal rods away from the RAM stick as directed, the RAM stick will pop up at an angle.
  9. Lenovo Essential G560 RAM Replacement: шаг 9, изображение 1 из 1
    • Gently pull out the stick of RAM.
    • If you wish to remove the second stick of RAM, do so by following steps two and three again.
Заключение
5 участников успешно повторили данное руководство.
Dennis Wong
Участник с: 01/11/13
609 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 18-40, Regan Winter 2013 Участник Cal Poly, Team 18-40, Regan Winter 2013
CPSU-REGAN-W13S18G40
5 членов
Автор 7 руководств
Один комментарий
maine apne lenovo g560 laptop me crucial 4gb ram add kiya lekin mera system format nahi ho raha h. mujhe kya karna chahiye mujhe email kare. vikasmaddeshiya056@gmail.com
vikkivikas056 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 20
За всё время: 11,124
