Введение
Use this guide if your current hard drive is damaged and needs to be replaced, or if you are simply looking to upgrade your storage.
Выберете то, что вам нужно
Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
Wedge the plastic opening tool into the small space under the back panel.
Use the plastic opening tool as a lever to separate the bottom panel from the computer.
Slide the tool along the edges of the computer until the bottom panel is completely separated.
Locate the three 3.5mm Phillips screws on the corners of the hard drive.
Remove the three screws with a size 0 Phillips screwdriver.
Follow the wire out from the right side of the hard drive to locate where the hard drive connects to the motherboard.
7 участников успешно повторили данное руководство.
4 Комментариев
How do you reload operating system.... for example windows 10?
Demo models of this do not have any SATA connector.
That sata connector is the worst thing ever
