Введение
If sound output is distorted, or no sound is coming from your speakers at all, then your speakers may need to be replaced.
Выберете то, что вам нужно
Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
Wedge the plastic opening tool into the small space under the back panel.
Use the plastic opening tool as a lever to separate the bottom panel from the computer.
Slide the tool along the edges of the computer until the bottom panel is completely separated.
Locate the speakers at the bottom left and right corners of the computer.
Locate the two 1mm Phillips head screws on both speakers.
Remove both screws from each speaker.
Locate where the two speaker wires join at the center of the computer.
Follow the wires directly upward to where they connect into the motherboard.
Using the spudger, pull the wire down and away from the motherboard to disconnect it.
