Lenovo Flex 6-11IGM Motherboard Replacement
Выберете то, что вам нужно
  1. Lenovo Flex 6-11IGM Motherboard Replacement, Back Panel: шаг 1, изображение 1 из 1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Motherboard Replacement: шаг 2, изображение 1 из 2 Lenovo Flex 6-11IGM Motherboard Replacement: шаг 2, изображение 2 из 2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Motherboard Replacement: шаг 3, изображение 1 из 1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Motherboard Replacement: шаг 4, изображение 1 из 2 Lenovo Flex 6-11IGM Motherboard Replacement: шаг 4, изображение 2 из 2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Careful: steps 5-7 are sourced from a guide that's marked as in-progress.
    Lenovo Flex 6-11IGM Motherboard Replacement, RAM: шаг 5, изображение 1 из 2 Lenovo Flex 6-11IGM Motherboard Replacement, RAM: шаг 5, изображение 2 из 2
    • Insert a plastic opening pick in the ribbon cable housing, flip the black part up, and pull the cable out with your fingers.
  6. Lenovo Flex 6-11IGM Motherboard Replacement: шаг 6, изображение 1 из 1
    • Remove the four 3.5mm Phillips #0 screws that secure the heat sink.
    • Remove the four 3.5 mm Phillips #0 screws that secure the heat sink.
  7. Lenovo Flex 6-11IGM Motherboard Replacement: шаг 7, изображение 1 из 1
    • Ram chips are soldered onto motherboard and cannot be removed.
  8. Lenovo Flex 6-11IGM Motherboard Replacement, Motherboard: шаг 8, изображение 1 из 1
    • Disengage the cable located above the left speaker.
    • Disengage the ribbon cable located directly above the battery using the blue pick.
    • Disengage the battery cable directly above the ribbon cable housing.
    • Disengage the CMOS battery cable located to the right of the battery cable.
    • Remove the display cable located directly above the button battery.
    • Disengage the secondary display cable located directly to the left of the display cable.
  9. Lenovo Flex 6-11IGM Motherboard Replacement: шаг 9, изображение 1 из 1
    • Using a Phillips #0 screwdriver, remove the five 3.5 mm screws that secure the motherboard.
    • Using a Phillips #0 screwdriver, remove the one 3.5 mm screw that secures the Wi-Fi chip, located above the button battery.
  10. Lenovo Flex 6-11IGM Motherboard Replacement: шаг 10, изображение 1 из 1
    • Remove the Wi-Fi chip located above the button battery from the motherboard.
    • Remove the motherboard from the case.
Заключение
Еще один человек закончил это руководство.
Jonathan Edens
Участник с: 09/16/20
235 Репутация
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 11
За последние 30 дней: 21
За всё время: 1,035
