Введение
Many of the replacement guides for this model will be internal parts that are accessed by first removing the back access panel. Removing this part is very simple; the only tool needed is a small Philips screwdriver to remove three screws. Removing this part gives access necessary for future guides.
Выберете то, что вам нужно
Remove the three 6mm Phillips #0 screws holding the back access panel on.
Slide the cover toward you to unlatch it.
The edge of the panel will slide away from the laptop so it can be lifted.
4 участников успешно повторили данное руководство.
