Введение
Outline what you are going to teach someone how to do.
Выберете то, что вам нужно
Turn off the computer.
Set the computer upside down with the back facing up.
With the battery facing you, slide the battery switch on the right side of the laptop towards the right.
Slide the left battery release switch to the left.
While holding the switch to the left, lift the battery to remove it from the computer.
Carefully pull the two metal retaining clips away from the sides of the RAM module.
Remove the RAM from the device.
Еще один человек закончил это руководство.
