Lenovo Horizon 2s Battery Replacement
  1. Lenovo Horizon 2s Battery Replacement, Rear Case: шаг 1, изображение 1 из 3 Lenovo Horizon 2s Battery Replacement, Rear Case: шаг 1, изображение 2 из 3 Lenovo Horizon 2s Battery Replacement, Rear Case: шаг 1, изображение 3 из 3
    • Flip the device so the rear case is facing upward.
    • With the plastic opening tool carefully pry the plastic piece shown in the picture, until it is completely removed from the case.
  2. Lenovo Horizon 2s Battery Replacement: шаг 2, изображение 1 из 2 Lenovo Horizon 2s Battery Replacement: шаг 2, изображение 2 из 2
    • Using your fingers, carefully remove the rubber boot from the right side of the rear case.
    • With the Phillips #1 head, remove the screw placed directly under the rubber boot.
  3. Lenovo Horizon 2s Battery Replacement: шаг 3, изображение 1 из 1
    • Using the plastic opening tool, push the display screen on the device forward until it separates from the rear casing.
  4. Lenovo Horizon 2s Battery Replacement: шаг 4, изображение 1 из 1
    • Using the plastic opening tool, carefully pry around the perimeter of the screen until the entire screen is completely separated from the rear casing.
  5. Lenovo Horizon 2s Battery Replacement: шаг 5, изображение 1 из 3 Lenovo Horizon 2s Battery Replacement: шаг 5, изображение 2 из 3 Lenovo Horizon 2s Battery Replacement: шаг 5, изображение 3 из 3
    • Before completely separating the screen from the rear casing you will carefully detach two wires that are connected to both sides of the device. This will allow you to completely separate the rear casing from screen.
  6. Lenovo Horizon 2s Battery Replacement, Battery: шаг 6, изображение 1 из 1
    • Using your fingers carefully and slowly disconnect the wire shown here from the motherboard.
  7. Lenovo Horizon 2s Battery Replacement: шаг 7, изображение 1 из 2 Lenovo Horizon 2s Battery Replacement: шаг 7, изображение 2 из 2
    • Using the Philips screw driver with the number 1 head. Carefully unscrew the six M2- 6mm screws that are circled in the picture.
  8. Lenovo Horizon 2s Battery Replacement: шаг 8, изображение 1 из 1
    • Carefully lift the battery from the rear casing.
Заключение
2 участников успешно повторили данное руководство.
Dustin Carro
Участник с: 09/25/17
224 Репутация
Автор 2 руководств
Команда
USF Tampa, Team S3-G6, Cannon Fall 2017 Участник USF Tampa, Team S3-G6, Cannon Fall 2017
USFT-CANNON-F17S3G6
3 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 15
За всё время: 1,566
