Введение
This requires only a Phillips head screwdriver. Be aware that only 2.5" hard drives fit in this computer.
Выберете то, что вам нужно
Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
Remove the two screws on the bottom of the computer, one on each side.
Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
Unscrew the four screws that hold hard drive enclosure to the hard drive, located on the side of the enclosure.
12 участников успешно повторили данное руководство.
5 Комментариев
you have been busy!!!!! Noticed the solutions , etc. below and that is impressive. chaosone7 @gmail.com
It’s nice and easy to get there, unfortunately the board was fried lol.
Can I replace the hard drive with a 1TB SATA III 6Gb/s 4-bit QLC V-NAND Flash 1GB Cache 2.5" Solid State Drive - Samsung QVO
The hard drive in this should be a 2.5” drive, so the replacement you listed should work
Do you have a better suggestion
