Введение
Be careful when lifting the WiFi card out of its slot not to damage the slot. Similarly, make sure that once it has been replaced that the two wires are securely connected to the card.
Выберете то, что вам нужно
Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
Remove the two screws on the bottom of the computer, one on each side.
Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
Locate the two small cables connected to the wifi card and pull gently to disconnect them.
2 участников успешно повторили данное руководство.
