Выберете то, что вам нужно
Lay the computer down on its side as shown.
Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
Using the Phillips #00 Precision screwdriver, unscrew the four 12mm screws that hold the fan in place.
Unplug the fan from the motherboard by gently pulling out the single plug. Then lift the fan up and out of the computer.
Loosen the four screws that hold the heat sink in place using a Phillips #2 screwdriver.
Pull the heat sink straight up to remove it.
