Инструменты
No tools required.
Запчасти
Никакие детали не требуются.
  1. Lay the computer down on its side as shown.
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Gently slide the side panel straight back and remove from the computer.
    • Gently slide the side panel straight back and remove from the computer.
  4. Push down on the white clips on both sides of the memory module to release it.
    • Push down on the white clips on both sides of the memory module to release it.
    • Gently pull up on the memory module to remove it from the unit.
Заключение
2 участников успешно повторили данное руководство.
Timothy Grebe
Участник с: 19.10.2014
1 319 Репутация
Автор 9 руководств
Команда
Cal Poly, Team 10-39, Amido Fall 2014 Member of Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
4 членов
Автор 9 руководств
Комментариев: 2
sounds very hard to replace a ram “sarcastically“
you probley can replace a ram if you know what ram is so
remliv - Ответить
But it is still good to have guides on everything
im glad that ifixit exists
remliv - Ответить
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 6
За всё время: 563
