Инструменты
Запчасти
No parts specified.
Lay the computer down on its side as shown.
Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
With your hands remove the 14mm screw that holds the cover on the back panel.
Gently pull the flap back to expose the T.V. Tuner screw.
Use the Phillips #2 to remove the 8mm screw that holds the T.V. Tuner in place.
With moderate force, pull straight up on the chip to remove it from the computer.
3 участников успешно повторили данное руководство.
Один комментарий
Why is a USB 3.1 Gen 1 adapter card called TV Tuner? It is an adapter card. What you connect to it is irelevant.
