Введение
In cases of hard drive or SSD issues, removing the defective hardware may be necessary. This guide demonstrates how to remove the SSD from the Lenovo IdeaPad 100S-141BR.
Required items will be a Phillips #00 Screwdriver and a Spudger. The removal process is simple and requires little to no experience to complete.
It is also recommended to have a replacement drive ready to replace it, but this is not required.
Выберете то, что вам нужно
Remove the eight 4mm PH00 screws.
Remove the four 2mm PH00 screws.
For safety reasons, disconnect the wires connecting the battery to the motherboard with a nylon spudger.
6 участников успешно повторили данное руководство.
3 Комментариев
WHAT DO i REPLACE THE ssd WITH ONCE REMOVED? I WANT TO UPGRADE TO A 1TB DRIVE. WHAT DO YOU SUGGEST FOR MY LENOVO 110S-141BR LAPTOP?
I replaced with an ssd but the laptop is not recognizing it
merci beaucoup
