Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement
Выберете то, что вам нужно
  1. Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement, WiFi/ Bluetooth Card: шаг 1, изображение 1 из 1
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement: шаг 2, изображение 1 из 2 Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement: шаг 2, изображение 2 из 2
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement: шаг 3, изображение 1 из 1
    • For safety reasons, disconnect the wires connecting the battery to the motherboard with the nylon spudger.
  4. Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement: шаг 4, изображение 1 из 2 Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement: шаг 4, изображение 2 из 2
    • Remove the tape and unscrew the single 2mm PH00 screw.
    • Pull out the current WiFi/Bluetooth card, unplugging the two wires connected to it.
Заключение
Follow the guide in reverse to reassemble your device.
Congratulations on successfully completing the WiFi/Bluetooth card replacement for your Lenovo IdeaPad 100s-14IBR laptop! By following this guide, you've taken a proactive step towards improving your device's wireless capabilities, ensuring a more seamless and reliable connectivity experience.
Remember to power on your laptop and test the new card to ensure it functions correctly. If you encounter any issues, double-check your connections and revisit the steps to ensure everything is in place. Feel free to revisit this guide or seek additional assistance if needed.
Еще один человек закончил это руководство.
Bin Feng
Участник с: 03/18/19
256 Репутация
Автор 2 руководств
Команду
University of Memphis, Team S1-G3, Kim Spring 2019 Участник University of Memphis, Team S1-G3, Kim Spring 2019
UM-KIM-S19S1G3
3 членов
Автор 9 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 14
За последние 30 дней: 48
За всё время: 2,018
