Lenovo IdeaPad 110-15ISK Hard Drive Replacement
Выберете то, что вам нужно
  1. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Keyboard: шаг 1, изображение 1 из 1
    • Flip the IdeaPad bottom side up.
    • Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
    • Flip the computer back to top facing.
  2. Lenovo IdeaPad 110-15ISK Hard Drive Replacement: шаг 2, изображение 1 из 1
    • Open the lid.
    • Use the plastic opening tool to pry the keyboard up and away from the bottom assembly.
  3. Lenovo IdeaPad 110-15ISK Hard Drive Replacement: шаг 3, изображение 1 из 1
    • Next disconnect the keyboard cable by using the tip of the spudger or your finger to lightly push out the ribbon from the contact port.
    • Completely remove the keyboard from the bottom assembly.
    • Unlock the ZIF conector before pulling the cable out
  4. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Optical Drive: шаг 5, изображение 1 из 1
    • Using a Phillips #1 screwdriver, unscrew the one 5.0mm screw on the back panel.
  5. Lenovo IdeaPad 110-15ISK Hard Drive Replacement: шаг 6, изображение 1 из 1
    • Flip the laptop to its back and the optical drive is located at the top left corner.
    • Remove the optical CD DVD drive by lightly pulling it out of the assembly.
  6. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Upper Case: шаг 7, изображение 1 из 1
    • Place the laptop bottom facing up.
    • Using a Phillips #1 screwdriver, remove the remaining eight 6.0mm screws on the back panel.
  7. Lenovo IdeaPad 110-15ISK Hard Drive Replacement: шаг 8, изображение 1 из 1
    • Separate the top case from the bottom using a plastic opening tool.
    • Continue prying the top and bottom case from each other all around the perimeter of the laptop.
  8. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Battery: шаг 9, изображение 1 из 1
    • Turn the laptop upside down and gently pry the top case free from the bottom case.
  9. Lenovo IdeaPad 110-15ISK Hard Drive Replacement: шаг 10, изображение 1 из 1
    • The battery is attached to the bottom case of the laptop.
    • Remove the two 4.0mm screws.
    • Push the battery component away from you in order to completely remove the battery from the fixture.
  10. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Hard Drive: шаг 11, изображение 1 из 2 Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Hard Drive: шаг 11, изображение 2 из 2
    • Using a Phillips #1 screwdriver, remove the four 4.0mm corner screws securing the hard drive assembly to the body.
    • Disconnect the hard drive from the back panel by sliding it to the left until loosened.
    • Remove it completely by lifting the hard drive out of the back panel.
  11. Lenovo IdeaPad 110-15ISK Hard Drive Replacement: шаг 12, изображение 1 из 2 Lenovo IdeaPad 110-15ISK Hard Drive Replacement: шаг 12, изображение 2 из 2
    • Using the Phillips #1 screwdriver, remove the four 3.0mm corner screws from the caddy of the hard drive.
    • Separate the plastic caddy from the hard drive.
Заключение
6 участников успешно повторили данное руководство.
Jakub Szark
Участник с: 10/17/18
513 Репутация
Автор 5 руководств
Команда
UW Tacoma, Team S1-G5, Rose Fall 2018 Участник UW Tacoma, Team S1-G5, Rose Fall 2018
UWT-ROSE-F18S1G5
4 членов
Автор 39 руководств
4 Комментариев
I found that two of the screws on the bottom hold down the keyboard, so they need to be unscrewed before the keyboard will come up. Also, there are two “shallow” screws (that become visible after the DVD drive is removed) which need to be removed, and the battery doesn’t really need to be removed to replace the hard drive.
et_rc992@etheli.com - Ответить
I’ve posted these comments on their associated steps, but it doesn’t hurt to repeat them here: There are 3 screws on the bottom of the laptop holding certain parts in place (keyboard & optical drive). These will need to be removed before doing anything else in this guide, so it’s best to just remove all 11 screws (yes, there are 11, not 10 as stated) from the bottom of the laptop. After removing the optical drive, there will be 2 more screws to remove. The screw underneath the keyboard holds the fan assembly in place, not the optical drive, as they are on opposite sides of the laptop.
Michael Wiseman - Ответить
Cannot remove optical hard drive following instructions. Does not appear to be removable on my Lenovo Ideapad 110.
Teresa Mcgervey - Ответить
Yes I have same problem and cannot remove the optical drive from my Lenovo Ideapad 110! Trying to add memory and can't do that until the optical drive is removed! Wth!
dsjh68 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 9
За последние 7 дней: 45
За последние 30 дней: 201
За всё время: 17,741
