Lenovo IdeaPad 110-15ISK Motherboard Replacement
Выберете то, что вам нужно
  1. Lenovo IdeaPad 110-15ISK Motherboard Replacement, Keyboard: шаг 1, изображение 1 из 1
    • Flip the IdeaPad bottom side up.
    • Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
    • Flip the computer back to top facing.
  2. Lenovo IdeaPad 110-15ISK Motherboard Replacement: шаг 2, изображение 1 из 1
    • Open the lid.
    • Use the plastic opening tool to pry the keyboard up and away from the bottom assembly.
  3. Lenovo IdeaPad 110-15ISK Motherboard Replacement: шаг 3, изображение 1 из 1
    • Next disconnect the keyboard cable by using the tip of the spudger or your finger to lightly push out the ribbon from the contact port.
    • Completely remove the keyboard from the bottom assembly.
    • Unlock the ZIF conector before pulling the cable out
  4. Lenovo IdeaPad 110-15ISK Motherboard Replacement, Optical Drive: шаг 5, изображение 1 из 1
    • Using a Phillips #1 screwdriver, unscrew the one 5.0mm screw on the back panel.
  5. Lenovo IdeaPad 110-15ISK Motherboard Replacement: шаг 6, изображение 1 из 1
    • Flip the laptop to its back and the optical drive is located at the top left corner.
    • Remove the optical CD DVD drive by lightly pulling it out of the assembly.
  6. Lenovo IdeaPad 110-15ISK Motherboard Replacement, Upper Case: шаг 7, изображение 1 из 1
    • Place the laptop bottom facing up.
    • Using a Phillips #1 screwdriver, remove the remaining eight 6.0mm screws on the back panel.
  7. Lenovo IdeaPad 110-15ISK Motherboard Replacement: шаг 8, изображение 1 из 1
    • Separate the top case from the bottom using a plastic opening tool.
    • Continue prying the top and bottom case from each other all around the perimeter of the laptop.
  8. Lenovo IdeaPad 110-15ISK Motherboard Replacement, Motherboard: шаг 9, изображение 1 из 1
    • Pull the two connectors with blue ribbons marked with MB in the opposite direction of the connector
  9. Lenovo IdeaPad 110-15ISK Motherboard Replacement: шаг 10, изображение 1 из 1
    • Using a Phillips #1 screwdriver, remove the marked four 4.0mm screws.
    • Pull out the hard drive.
  10. Lenovo IdeaPad 110-15ISK Motherboard Replacement: шаг 11, изображение 1 из 1
    • Using a Phillips #1 screwdriver, remove the five 4.0mm screws.
  11. Lenovo IdeaPad 110-15ISK Motherboard Replacement: шаг 12, изображение 1 из 1
    • Using tweezers, pull the four marked connectors out and away from the motherboard.
    • Remove the WIFI card by pulling up and away from the motherboard.
  12. Lenovo IdeaPad 110-15ISK Motherboard Replacement: шаг 13, изображение 1 из 1
    • Pull off the motherboard.
Заключение
2 участников успешно повторили данное руководство.
Jakub Szark
Участник с: 10/17/18
513 Репутация
Автор 5 руководств
Команда
UW Tacoma, Team S1-G5, Rose Fall 2018 Участник UW Tacoma, Team S1-G5, Rose Fall 2018
UWT-ROSE-F18S1G5
4 членов
Автор 39 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 14
За последние 30 дней: 38
За всё время: 4,167
