Введение
If the Lenovo is unable to read a disc, the optical drive may be broken. To replace the optical drive, follow the provided guide.
Выберете то, что вам нужно
Flip the IdeaPad bottom side up.
Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
Flip the computer back to top facing.
Open the lid.
Use the plastic opening tool to pry the keyboard up and away from the bottom assembly.
Next disconnect the keyboard cable by using the tip of the spudger or your finger to lightly push out the ribbon from the contact port.
Completely remove the keyboard from the bottom assembly.
Using a Phillips #1 screwdriver, unscrew the one 5.0mm screw on the back panel.
Flip the laptop to its back and the optical drive is located at the top left corner.
Remove the optical CD DVD drive by lightly pulling it out of the assembly.
Один комментарий
Hi, I have an Lenovo ideapad 110-15isk laptop. The size of the optical drive is 9.0 mm. Can I trace the 9.5 mm specimens ??because there is no 9.0 mimeter available now? Thanks s lot.
